I’m super confused by this forums platform and how to put things in the proper categories so please bear with me, where ever this ends up.
I’m having some software issues with engraving photos using a rotary roller. My pulses per rotation is accurate, my belts are tensioned properly and in good shape, the roller is square with the gantry, and the machine itself is functioning as should. I’m using an OMTech 80w CO2 Ruida controller.
When I engrave a “fill pattern” such as a business logo image trace, I have no issues and the machine functions properly. However, when I engrave an image in newsprint or any of lightburns other dithering options the engraving slants. Almost as if the machine is losing steps while it rosters back and forth. I’m wondering if it’s a software issue either in my machine or with LightBurn because not all photos do it but the ones that do always do it. I also ran a test to see what would happen if I shut the rotary off on LightBurn (still leaving the rotary plugged in knowing the image would not give desired results) and the result I got was no slanting. Strange, right?
I did notice that sometimes the machine would roster back and forth as usual but let’s say my engraving is 3” wide… it would roster left 3” then right 3” then left 3” and then would only roster right 2.75” then would return left and then come back right 3” it seemed at this point the slanting would begin.
Any ideas helps, thanks guys!
I’ll try to attach some photos.
