Rotary slices/framing
No matter what settings in rotary “split size” and “overlab” I always only get a maximum of 2 slices, when framing (inside a ring). I need more slices, because the ring is not flat, so the framing is bending. It works a bit different in Ezcad2, where I can see each letter, and I want the same for lightburn. Im trying not to switch between the two programs and lightburn fits my needs better for all other topics than ring engraving. The setup is good to go. The rotary works and I have succesfully engraved inside and outside a ring. Please smaller slices/framing/preview - any suggestions?
I can’t give you a fix but I see no one else has answered, I do a lot of slicing so I’ll give you my opinion. Might help with your strategy…
I do projects with several thousand slices. but when I frame I get 12. I just think there is a limit to slice framing and it isn’t really designed to show every slice. It can’t. I can’t imagine the processing power required to generate and show 20K slices. Try making your slices larger for framing, after you have what you like go back and change the setting to small slices. Try “Run whole Shapes”. Or turn it off. Post screen shots of the windows leading up to framing I can take a look, maybe see something.
I am assuming you are talking about the framing done from inside the rotary screen, not the main framing screen.
