Silvers
(Eamonn)
May 12, 2019, 3:26pm
1
K40, Smoothie on C3D mini running LB 09.02
Not used my rotary for cutting for a while now but I’m having an issue when cutting squares out.
The speed is OK when X is going +ve but when its -ve it slower causing increase in burning.
Checked the G-code and every time the X speed is always slower for some reason.
Tested on circles and other shapes and its all good.
This only happens on squares.
Any ideas guys.?
File attached of basic square G-Code in picture format, forum won let me upload Gcode file…
Silvers
(Eamonn)
May 13, 2019, 1:22pm
2
Up-date.
Did many many more runs and when “fill” is selected it works perfectly.
Select it to cut and it cuts 3 sides at the correct speed but when doing the return cut on the square it slows down.
I have tested this on flat using X/Y and it works perfectly every time.
picture of the G.code with cut using x/y
.So I still cant it to do what it used to do…
If I can find an earlier version will drop back to that see if it does has the same issue.
Any help or suggestions would be appreciated.
Silvers
(Eamonn)
May 20, 2019, 2:45pm
3
Ok. Managed to finally get some more time on this.
Whenever I use Rotary on fill it works right.when I try to use it on cut it still changes speeds on each cut @LightBurn any ideas ?
I have tried laserweb and it works accurately each time.
So I k ow it’s not the rotary device I have.
Tried to drop back to an earlier version but it won’t let me install.
I believe I have this fixed. Will need to do a little more testing, but there was a reasonably obvious bug in the calculation for feed rate when using current position or user origin modes.
system
(system)
Closed
June 4, 2019, 10:59pm
5
