Rotary starting point
How do you select a starting point on a rotary ?
Generally you use “Current Position” mode, and just jog the X / Y until you’re at the place you’d like to start. You can use a center job origin and place the laser at the center of where you want the engraving, and that’s usually the simplest option.
Can you tell me where the curent position mode is set?
Right here:
You can read about how it works here: https://lightburnsoftware.github.io/NewDocs/CoordinatesOrigin.html
Thank you SO MUCH
