When starting a new project on my AP Laser Sn4024 the rotary the drive wheels are turning too fast and causing the cup to fall off the rollers. I frame it and it runs slowly but when I hit start the initial startup is too fast. How can I slow the startup down? Thanks
Go to Edit > Machine Settings and lower the Idle Speed value when using the rotary. This is the speed the system uses when moving between cuts.
