Rotary table and different engravings.
Hello,
I have a ComMarker XE UV galvo laser and a rotary table that I am trying to get working properly. I have discovered that I can use repeat marking and adjust the angle to engrave specific areas while the part is mounted in a jig.
Is it possible to engrave different patterns, logos, or names on the same part, or is it only possible to engrave a single design that is repeated as the rotary table turns?
Maybe you could treat the rotary as linear and do what you want, it would take some experimenting to get the steps correct and use “Run Whole Shapes”. Sounds similar to another post engraving on 2 sides of a part. Software not designed for this but pretty sure with a little trial and error you could do it.
