I have purchased a rotary table to be able to set up multiple items for lasering.
How do I get the table to turn a certain distance to the next item for lasering, Laser is a 60W Galvo. Rotary table turns using the existing chuck setting but keeps returning to start (I did turn off the return function) but still returns. Can this be done in LB with different lasered words per Item I.e cable tags etc.
Following along.
Turn off “Enable Rotary” and enable “Repeat marking” . The settings will allow what you are asking.
I haven’t tried dynamic marking with a galvo and a rotary table, so can’t answer that but hopefully someone will come along with experience. I am curious if that is possible as well.
Hi Al
thank you for the details I will try these settings and see how it goes.
As you say, hopefully someone will assist with the dynamic settings
To the best of my knowledge, there shouldn’t be anything preventing you from using Variable Text along with the Repeat Marking function in LighrBurn. Feed it a .CSV file with the data, and use the appropriate variables in your file setup to pull in the data.
Just did a search, and this forum post came up that confirms it works:
I remember that thread. I keep meaning to try “Next time” I set up the table but keep forgetting!
