Rotary tool issue with ortur and LightBurn
Error code when trying to Starting stream
ALARM:2
G-code motion target exceeds machine travel. Machine position safely retained. Alarm may be unlocked. (Right-click the ‘Devices’ button to reset the connection)
On or near line 2:
Stream completed in 0:00
[MSG:Reset to continue]
ok
Ortur Laser Master 2 Pro S2 Ready!
OLF:OLF 185.
OLH:OLM_ESP_PRO_V1.2.
OLM: GENERAL.
[MSG: Flame detector active,Ambient infrared value:0]
Grbl 1.1f [‘$’ for help]
[MSG:‘$H’|‘$X’ to unlock]
[MSG:Caution: Unlocked]
ok use my rotary tool. First time using it.
You may need to disable ‘Soft Limits’ in your laser’s firmware - sometimes the distance the rotary is commanded to move/turn exceeds the ‘Y max travel’ limit set in your laser’s firmware, which triggers that Alarm 2 message. Disabling ‘Soft Limits’ will prevent that.
Here’s a video guide on doing that. I recommend watching the entire video - it covers the fully rotary setup process:
