Hello,
I know that light burn and the Trocen controllers can not communicate when it comes to the rotary settings. I have gone into the controller and have input all of the required info to rotate the rotary. I start and stop at the same point on the tumbler when I rotate manually and tell it to frame the design from lightburn. The issue is when I run the actual program it just goes back and forth in X but does not move rotary. What am I missing thanks.
AWC708S is the controller thanks.
Also. I forgot to mention it uses the y driver through a aviation plug. If I don’t enable the rotary setting it will run with the program but will be stretched out and spaced out between steps. Once I enable the rotary setting it won’t run with the program but will run manually.
