I setup my Rotary using rotary setup in Lightburn build1.4.05 with a Genmitsu Laser Engraver Aluminum Y-axis Rotary Roller Engraving Module. Did a Test run and tuned it as close as i could get and it Works great in test mode. Run a etching job and the y axis won’t stop rotating. Tried resetting and no difference.
Any help would be appreciated
What do you mean by test mode? If you click on the test button in the wizard? This should turn the rollers once (360°), if you tuned it to turn the object once, the values are way too high.
Thank you. Stupid mistake on my part. All good now.
