Rotatable Red Dot Pointer
Hi.
I have just got 130w laser that does not have a red dot pointer. I have tried the ones that mont to the head and points at an angle… And the ones that are inline using a collomunating (sic) lens.
The inline system seems to loose too much of the red laser power… and I am worried about loose too mush of the 130w laser power.
The angled system only works when you are at perfect height.
What I am looking for is a solution using a servo motor that can rotate the red dot laser into the laser path… thus helping with alignment… and then automatically rotate it out of the way when not being used.
Has anyone seen something like this?
Some people use a pair of laser pointers that protect a slit type output.
Amazon has these…
Mounted on the sides, it produces the same spot at any altitude.
I ripped mine out because of what you complained about… I do without a pointer.
