Rotate the whole View in Lightburn
Hi!
I’m curious, is it possible to rotate the whole view in Lightburn? The Origin of my Laser is bottom left, but the Laser is located next to my PC and the whole Laser is rotated by 90°
So the correct aligement would be a lot easier, if i could just rotate the view in the software. Is there any chance to do this?
Thank you & best regards,
Andi
There is no way to do this, no. It’s hard enough for people to understand the various orientations and origin positions, so I’m not in a rush to make this worse. :slight_smile:
Ok, thanks for the answer. So i will have to rotate the Laser itself, otherwise im confused all the time :smiley:
You could swap the X & Y motor connectors on your machine.
You may need some GRBL-fu to switch directions with $3
Alan
