Is there a way in Lightburn to specify how much to rotate a drawing object or see its angle in degrees as it is rotated?
At the bottom of the screen there’s a status bar that will show you the rotation angle. Alternatively, use the Numeric Edits toolbar to manually enter a degree rotation.
Note that you can use the Measurement Tool to check the angle after the fact.
Thank you. I had looked in that area earlier but somehow missed seeing the angle info.
Yup.
I was missing something here.
I had been associating the Unit Toggle Button with the Rotational Text Field from the beginning.
Perhaps, as a suggestion, splitting them to a different line?
It would even be nice to see that number update dynamically… like the Width and Height do when drag-scaling a selection. Such a feature would have also demonstrated that the field was degrees of rotation, rather than a lineal distance as I wrongly assumed.
Jim
