RPi5;Win 11 ARM;USB Driver?
Hello all:
Rpi5 8GB with a Pi 512GB Hat. Creality GRBL 10w laser with air
I installed Win 11 Arm using BVM and then Lightburn. Works like a champ. The issue is the USB Passthrough. When I look at the USB Passthrough on the GUI, my key board and mouse show up but not the USB controller on the GRBL board. Is there a driver needed like CH430 or is this just a waste of time?
The Laser works fine in a normal windows environment.
Respect
John
Yes…
Firstly, serial USB devices like GRBL boards (never actually done it with GRBL - only industrial stuff) can be very picky with passthrough in virtual environments. (Source: pain and suffering) – never played with Win11 ARM though.
Most Creality (and generic GRBL) boards use one of:
  • CH340 (very common in Chinese clones)
  • FT232R (FTDI)
  • CP2102 (Silicon Labs)
(1) Even if the host sees the USB device, Windows 11 ARM needs its own driver to talk to it…So, yes Win11 might need a new driver.
Also…
Ensure the device is selected for passthrough. You need to manually enable or forward the USB device to the VM, it’s not automatic (like for keyboard / mouse). Never done this for GRBL - but it might be in the VM config. Something like:
-usb -device usb-host,hostbus=1,hostaddr=4
might work
Assuming you know the hostbus and hostaddr via the PI :slight_smile:
Get this via PI terminal
lsusb
(2) Try disconnecting and reconnecting the USB cable after booting into the VM. Possibly a folk remedy - but what the heck.
(3) Not sure if the Pi5 is USB3. Sometimes USB 3 crapps out on VM. Do you have and old USB2 hub? If so connect that to the PI and Creality to that. (Source - pain, suffering. Google).
You can try the ch341 driver here: CH341SER.EXE - NanjingQinhengMicroelectronics
No guarantees
I’ll have a look when I return home and let you know what I find. TY
