Rubber band outside and inside?
Can the rubber band tool be applied to the inside of a doughnut (to hug the inside circle of the doughnut) and also have a shape welded to the inside of the Inner rubber band.
Outer rubber band
Gap (with content)
Inner rubber band
Shpe/Image
You’ve got a doughnut shape—outer ring, gap in the middle, and then the inner ring. You want to use the rubber band tool (LightBurn’s shape-tracing or offset-like selection tool) to hug the inside of the doughnut, and then weld a shape or image to that inner curve. Here’s the honest breakdown:
Can you do it?
Sort of—but not directly with the “rubber band” tool the way you’re describing. Rubber band selection in LightBurn is mostly a selection tool, not an object manipulation tool. But I get what you’re trying to do: hug the inside path and weld something to it.
So here’s how you actually pull that off:
Step-by-step: Hug the Inside of a Doughnut and Weld a Shape
  1. Create Your Doughnut
  • Draw two circles: one big (outer ring), one small (inner hole).
  • Select both, go to Boolean Subtract or Weld (depending on order) to get your actual doughnut ring shape.
  1. Use Offset to Trace the Inner Curve
  • Select the inner circle before welding.
  • Use Offset Shapes and select Inward, set a small offset like -2mm if you want a tight trace.
  • This gives you a clean path hugging the inside of the doughnut.
  1. Place Your Shape
  • Bring in your shape or image.
  • Position it so part of it overlaps that new inner offset curve.
  1. Weld the Shape to the Inner Curve
  • Select both your shape and the inner offset line.
  • Use Weld or Boolean Union (depending on whether your object is open or closed paths).
  • This’ll merge the shape into the path that hugs the inner edge of the doughnut.
So to be clear:
  • Rubber band doesn’t “snap” to edges—it selects.
  • Offset is what you want to trace the inner edge.
  • Once you get that curve, welding other vectors to it works like any other shape.
