Rudia controll menu for manual speed
Can someone tell me where in the Rudia command screen where to adjust the manual speeds for X and Y. My laser before updates moved fairly fast now it manually moves at a snails pace. I think the Rudia reset parameters messed up this setting. Thanks in advance for any possible answers.
I have a 6442g type Ruida, there isn’t a manual speed setting for each axes, that I know of.
If you press the speed button on the machines console you can set your manual positioning speed there… as far as I know, it applies to both axes.
If I follow you… Lightburn doesn’t write to the controller unless you ask it to, such as when you enable the rotary, but it doesn’t change values of other settings.
