Rudia Controller 50w Chinese Starts, Stops. Reset-Enter Works
Last night I tried to laze the LB Focus Chart. Since then, my laser is messed up. When I send a job, the head moves to the starting position and stops. To get it to work, I press Reset, wait for the Esc/Enter restart prompt, and press Enter. Lazes correctly from that point. Help! Why does it stop. It is definitely software (LB or Controller) as it stops at the first laze position every time. Thanks in advance for your thoughts.
I seem to be having a very similar problem. Except mine runs for about 10-15 seconds into the cut job and then stops. I’ll try the rest/enter fix.
PROBLEM FIXED! The issue was in the LB file. I started a new file and it works correctly now!
