Limit switches configuration issue or hardware issue.
- Ruida Controller 6445G
- N.O. Switch’s installed on - X-Axis & - Y-Axis
- X-Axis N.O. Wire connects to (CN4) pin 4 Phoenix terminal that says (X-). The common wire from the - X-Axis connects to (CN4) pin 1 on the Phoenix terminal that says (Ground)
- When the controller is powered on and I trigger the limit switch, the -X led on the controller Illuminates. = this is correct
- Without the switch activated the LED on the controller is NOT illuminated = this is correct.
- Without the limit switch activated, the display in +diagnosis lights up saying it’s triggered but the physical switch is not triggered.
- With the display led that says the limit switch is triggered (X-Axis) it will not let you log the machine.
- When I described the limit switch in the software/display it will allow me to jog = this is correct.
Issue is that the controller where the input wires hook up into it acts correctly when a limit switch is activated by illuminating. What doesn’t make sense to me is in the display it says it’s activated but the switch is not; almost like the controller and display are out of synch?
Any suggestions?
