Good evening, I apologize for the long post, I hope someone will help me.
I write because there are some questions that I can not solve. I state that my 80w 60*40 co2 machine arrived with a bit of a hitch, the seller had reversed my address with another customer who is over 1000km from me, despite the fact that he had ordered a 60w and I had ordered an 80w. He got mine (80w) a week earlier and ‘unfortunately’ didn’t notice, so he opened it and started using my machine. When I got his (60w) I immediately noticed, so I contacted the seller, who realized the mistake, and contacted the other customer asked him to pack and send me mine, and me to send his (which was packed and intact)
The machine was then tossed around Italy, and since it arrived it has never worked perfectly.
I have tried several times to point this out to the seller, but he doesn’t seem to understand my complaints.
At first the right&high end switch didn’t seem to work, and after reading on this forum the pin where it should be connected, and I discovered that the wire was disconnected.
I have done tests with equal speed and power, but with air on and air off, but see no difference with the air assist.
About 3 weeks ago out of the blue the laser was not working anymore…
I wrote complaining heavily to the seller, who told me to disconnect the red wire (the first on the right) of the laser power supply. And the machine started working again… but I lost the red dot light.
I then wrote back to the seller, saying it was working now, but I was without red light. and he replied “yep, just use it without red light”.
Does anyone have a map of the connections as a controller I have a Ruida RDC6442s-b(ec)
So with calm I check everything ?
Thanks
