RUIDA Rotary xasis problem
Hello Everyone
I am having problems installing rotary axis …Firstly everything was ok for some champange glasses it makes good but for some other it is making the writing and some small vectors streched…is there any problem with software or settings parameters?
Welcome to the Forum…
Drag and drop a photo of the anomaly… it would be very helpful for us to see what you are trying to describe. As a new user, you have limited number of photos you can post (drag and drop on the reply edit window).
The most common cause is slipping when trying to do vector graphics. This usually occurs with a wheel or roller type rotary… You didn’t mention which one you are using…
If you’re using a chuck type… different path to resolution…
