Run 2 on one license
can I run 2 lasers from one LB license? ortour 20w diode and 30w omtech mopa fiber. how do I set this up? LB is the 1.4.01 version
Yes. Open 2 instances of LightBurn and connect to a different laser in each instance.
You can open instances easily with File->New window.
Yes, you can. You will need to purchase both the GCode version and then add support for the galvo to your key if you haven’t already. :slight_smile:
Grab your license key and head here:
If you are running simultaneously then follow @berainlb.
I have grbl, Ruida and a MOPA and I run them all with different device settings… one at a time…
With Ethernet/UDP the Ruida is pretty dumb, I can connect two computers to it, design and ship it from the office and control it out in the garage…
Haven’t tried it with the Lightburn Bridge, but it worked fine with it on the lan…
Good luck
