Run G-code on Ruida Lasers
I don’t have the DSP version to test so dumb question, Can I import G-code files into Lightburn and run them on Ruida machines?
You can’t, no - they’re not gcode based. The DSP version of the software is required to talk to them. Having said that, if you have one (or access to one) you can deactivate your copy of LightBurn and send me your trial ID, and I can extend the trial. The trial contains all the device drivers, so you’d be able to test it with the Ruida.
