Is there a way to have LB upload and execute the job from memory on the laser (GRBL [VER:1.1h.2022070601:]), rather than streaming it from the software like Run GCode (and Start) does?
I’d like to avoid failure if the USB connection is lost while running a job.
File->Save Gcode, pick a file name and save to SD Card. Transfer card to laser and run from the available menu. Some machines may be picky about the file extension so you may need to experiment with that.
Also, if your laser has a web page that you can upload to, you may be able to avoid the SD card roundtrip.
If the Telnet over Wifi is an option as Gil has suggested, then that would avoid USB but is still a streaming method so you’d have to decide what’s important for you.
I have replaced the Falcon 10 with a GRBL ESP32-based 20W unit. I was able to save the .gcode from LB and upload/run it from the web interface. Thanks again to all!
No, and as I don’t trust this date detection, I have always only one file on the card.
And yes, it is very unpractical. A little display to select a file would be so convenient for this usage!
