does anyone know if i can run two machines at the same time from 1 computer
Was going to ask the same question, searched and found this question, no luck with an answer yet?
from what i have found out so far, it may be possible to connect 2 machines via 2 usb ports then open 2 instances of lightburn and connect each with a different com port. dont want to buy a 2nd machine until i know, expensive way to test lol
Perfectly possible
2 instances of lightburn, 2 machines, 2 different COm ports
Is a bit mind confusing but doable without problems
Thanks Gil, probably the way i will try.
