Running multiple lasers in one instance of Lightburn
I use a Monport GPro 100W Split MOPA Fiber Laser and the company I work for is ordering a second to increase our ability to produce. I want to know whether I can use a single instance of Lightburn to run multiple lasers if that’s possible or whether I’ll need to use two separate instances. We haven’t received our second laser yet and i’m still fairly new to Lightburn and what the capabilities are.
You can go File > New Window to open up two LightBurn windows, each can control a different laser. Or, you can switch between devices on a single window.
Yes another instantiation if you wish to control two simultaneously.
USB:
You need to use separate USB COM ports for each laser. You cannot use a hub.
Ethernet or WIFI:
The lasers must have different I.P. addresses.
