My SCULPFUN 5W runs but won`t laser cut. Anyone has any idea on what my problem is?
Could you share a screenshot of your lightburn project, showing the layers tab so we can see what settings you have
Also in Settings are you on mm/min or mm/sec
lastely, image of edit _> device settings?
working on a picture its set on mm/min
Did it work before? Then, most likely the signal cable is broken. You can check by doing the 5V test (Guide to mechanical adjustments and maintenance)
How do you download pics
it still does using my phone
I don’t get the problem, could you explain a little more?
