How can I recut graphics as first cut was too light
if you have not moved your topic, you just burn one more time. You can use, for example, another angle (crosshatch), but as I said, it requires that you have not moved your subject.
Thanks I will try that
As @bernd.dk says, “if you have not moved your topic”, or have a way to re-register the work, you can also use the ‘Start here’ found in the ‘Preview’ window. Scrub to where you want to start again and click the button for options.
