Installed limit switches. Homes and jogs correctly but i go to start anything from home position it tries to come forward and hits the rail and stopsHoming
ok
$0=10
$1=25
$2=0
$3=4
$4=0
$5=1
$6=0
$10=1
$11=0.010
$12=0.002
$13=0
$20=0
$21=1
$22=1
$23=3
$24=200.000
$25=3000.000
$26=250.000
$27=2.000
$30=1000.000
$31=0.000
$32=1
$41=0.000
$40=0.000
$100=80.000
$101=80.000
$102=250.000
$103=100.000
$104=100.000
$105=100.000
$110=6000.000
$111=6000.000
$112=1000.000
$113=1000.000
$114=1000.000
$115=1000.000
$120=1000.000
$121=1000.000
$122=1000.000
$123=200.000
$124=200.000
$125=200.000
$130=375.000
$131=380.000
$132=200.000
$133=300.000
$134=300.000
$135=300.000
ok
Position laser x20 y31 and it hits the rail
Starting stream
Stream completed in 0:01
ALARM:1
Hard limit triggered. Machine position is likely lost due to sudden and immediate halt. Re-homing is highly recommended.
Everything is reading in mm
I opened laser GRBL, got the same readings when i jogged it up and right 10mm each
Hit the home button then hit zero home and it zeroed everything. Opened LB and the settings zero there as well.
If i close it out and close laser GRBL i do have to re zero it again.
Not sure what i can do to keep the settings permanent but it is working as it should
Okay, it is working, but the position info is confusing, right?
In the Console window, enter $$, and then $#. Copy and paste the results from the Console window to a Reply here. I have the S30 Pro, so our settings should be very close.
As an afterthought, make sure the rotary is not enabled.
Your GRBL parameters are the same as mine for nearly everything.
This should read zeros all the way across. You have a work coordinate offset enabled. This will affect positioning and readouts. In the Console window, enter G10 L2 P1 X0 Y0 and then test.
