Hello guys! I have a problem with my Sculpfun S9. Everytime I turn it on, the power light and adaptor blinks. I tested my adaptor and it seems to be working fine.
My only option now is to buy another motherboard. I am from the Philippines and there are no official store online, and no physical store either.
Ran across with this post and I am not very techy. I am afraid of voltages and other else. Will this be compatible with my s9? My s9 originally doesnt have an auto air assist feature but I am tempted with this.
However the fact your power adapter can output voltage does not mean necessarily is a good power adapter
I would suggest
a) unplug laser head from machine and power on, same behavior
b) use a replacement - similar spec - power adapter to test
Hello I followed your advice and unplugged the laser head and the blinking stopped!! So I tried to ruled out what caused the blinking and its this slot her
To me, it looks like a faulty power supply as well. It’s usually not the connector on the board, it’s the device you connect to it that needs the power and kills the faulty power supply.
