Safety door detected as opened and door state initiated
Hi,
Hoping someone can help, recently purchased a Omtech K40+ setup all went fine, but I can’t frame with the door open. This is a European model so has a reset button that must be pressed every time the door is shut which then initiates the laser power.
I get the following with the door open
error:13
Safety door detected as opened and door state initiated.
<Alarm|MPos:0.000,0.000,0.000|FS:0,0|Pn:D|WCO:0.000,0.000,0.000>
ok
Starting stream
error:9
G-code locked out during alarm or jog state.
On or near line 0:
Stream completed in 0:00
‘$X’ to unlock
error:9
The door window is so dark I can’t see inside so can’t frame that way either. Omtech support has not been helpful at all, So currently have a machine that I can’t frame with.
Thanks
That’s a firmware thing. You can’t do anything about this in LB. You only could disconnect / fool the door sensor to make it work then.
Thanks. I have zip tied down the door switches.
