Has anyone put together this machine and successfully made it work? I am looking for the general settings almost like a printer driver for this machine. This would get me close and then be able to tweak as necessary. It also will not home correctly.
After a quick google seems to be a 300x180mm
Should be able to connet it via grbl and it shoudl read most from its controller
What exactly are your troubles?
I have a 3018. I retro fitted limit switches and it all works flawlessly with Lightburn.
You do however have to set the offset as outlined within the Lightburn documentation (common Grbl Setups). Let me know if you need anything else.
