Hi,
maybe I am blind, but: Is there an option to save different cut settings in Lightburn? Eg for: engraving in plywood, engraving in acryl etc.
I don’t know I’m here learning my self but is gimp is where u would set your image in to fit the the plywood with and add on called (Da Gimpying )
Emmm, no. I meant: Speed, Max Power, No of passes.
The cut library will manage the power settings and speed. I’ve not had to use the number of passes feature, so I can’t directly advise regarding that aspect, but I would not be surprised if it stored that information.
I keep my library in the cloud, which gives one machine access for updates performed on the other.
Thanks!
I was blind!
