Save G-CODE to use in CANDLE
I saved G-Code from LB. Try to open in CANDLE and it does not work. I have spent several hours reading on the WEB.
I have followed edit suggestions from variuos posts. Nothing.
I know that this is not exactly an LB issue. However, I suspect I am not the first person experiencing this.
Can you elaborate? “Does not work” isn’t much to go on!
Lightburn can Save the same extension candle understand. Albeit GCode is text.
CANDLE does not read the file. I know it’s a text file. I wonder if LB is adding something that CANDLE does not recognize. My test file is just a simple circle.
CANDLE shows the command lines but does not draw the object.
I figured it out.LB does not export the Z axis values. Once I added that then CANDLE interpreted the file correctly.
Candle is extremely outdated and a bad tool. If you are controlling a CNC, try gSender. Much better. I didn’t test if it can handle gcode without z values, but I guess so.
Fully agree on this one, Gsender is great (and free). When you are looking for a good 2D program to design your CNC work, try Carbide Create, version 622 is a bit older but also free and has a great option to save the GRBL files including toolpaths.
