Hi All,
Is there a way to save cut/fill settings within a project so that when I return to it later, everything is the same?
The issue I am having is that I set up a project, complete it, then move on to other stuff using different media, and adjust the setting to suit that. Then when I get another project from a repeat customer, I bring up the previous file to mimic the setting, and the settings have adjusted to last file created. I think this makes sense, but ask, and I’ll clarify.
Regards,
Keith
Hi Keith.
Good question, Is this of any use:-
Are you opening or importing the file? If you import, it is only bringing in the graphics. If you open the file it should have the settings that it was saved with.
This is also a good case for using the materials library.
Thank you, I will try this out. Lots of repeat request so if this helps, I’ll certainly use it.
