Hello,
I think I understood how to make tabs and this is a great feature !
Is there a way I can export the modified drawing to a vector file or is this feature intended only for use with the laser cutter ?
Thanks,
Gilles,
Yes, you can set the tabs as you’d like, then with the shape selected,
- Go to: ‘Edit’→’Convert to Cut (debug)’ to bake the tabs into a copy of that shape
- With that new shape selected, then go to ‘File’->‘Export’->‘Save as SVG’
The result should be a vector set of shapes as you’d expect.
Thank you very much, it works !
