I am using a 60W Co2 laser cutting machine after cutting there is sawtooth marks left on either on x-axis or y-axis on edge of acrylics material.
Have anyone experienced this problem or how to solve it?
Thank you.
I believe this video may help you.I found the information a step toward resolving the issue I was seeing
Thank you, Rooster. Will try out and see how is the outcome.
Hi Rooster1956,
Too bad… i have adjusted the speed, power and weaken air blow the outcome of the cutting result still showing sawtooth marking. I have just replaced X & Y- axis bearing also didn’t improve much.
The result seem strange as the sawtooth appearing on bottom edge and right side edge of the cutting piece.
But still many thanks for the video… and i learn something new.
