Says open shapes not closed but have been closed
Lightburn keeps saying two shapes weren’t closed so i can’t fill. I’ve gone over the shapes and looks like they are closed just fine (even the close path/ auto-join path options are grayed out). When i select the shape it selected the whole vector and not just a piece so am trying to figure how to get this to accept. what could i be missing?
You may have a little tiny piece of scrap that is causing the warning.
When you press PREVIEW and get the warning, choose the “Show me”. It should select the shapes that are not closed. Put them on a different layer and turn that layer to NO OUTPUT.
Do you have solid fill selected? Are your shapes filled in on the screen?
Post a screen capture so we can see what you are seeing.
sorry it was referring to another vector on the file i wasn’t looking at. I’ll be deleting this post :man_facepalming:
No problem. No reason to be sorry. We all started as Newbies, sometime.
I like to run the “Print selected items only” tab turned on. That way I have to select by hand what is included.
