Scoring problem
Hello everyone,
I’m facing a small issue. I sometimes use the line mode to « dress » my cuts, but i’ve noticed the lines are unsightly and that the laser burns more when changing direction (see photos).
Do you have any idea how to eliminate this problem and smooth out the lines?
Machine: Omtech Max 750 100W CO2
Line settings: Speed: 150mm/s, Power: 22%
Thanks!
All machines are different, but I think 22% power is a lot for a decoration line. You don’t write anything about your minimum power setting, this is where you can experiment a little to get rid of the overburned corners. For example, for similar tasks, on my 60Watt machine, I use approx. 15% max, 8.75% min power and between 150 and 200 mm/s in speed. Your min power can easily be higher, it depends on where your machine’s “ignition start” is.
Here’s a small test that should make visible what I mean.
Thanks that’s it ! I put 10% on minimal power and I have now clear lines
