Sculfun S6 to Sculfun S9
Will a Sculfun S9 module work on a Sculfun S6 Pro
. I would like to upgrade. Thank You
I assume you’re referring to the laser module? Pretty much all laser modules will work on all controllers but may need supplemental power or a different connector to make sure the pins are aligned properly. The main thing to look out for is if voltage matches between the controller and laser module in which case you may need separate power sources.
In the case of the s9 module vs s6 pro they look like they’ll be pin for pin compatible and have the same power rating so should be a direct swap. In fact, the pictures on the website are duplicated for the two.
S6 Pro:
S9:
Thank You that is what I was hoping for.
