When I start a work the laser goes only to the right and keeps going, from the terminal I get alarm 3
Hi Mattia
Can you post the make and model of your laser and if it is fitted with Limit-Switches.
The S30 Max is a 20w Sculpfun and has limit switches. They are mounted in the front-left corner.
With a cold start from the center, does the module travel in that direction when it connects to Lightburn?
Oh right!..That would be in the TOPIC info right there at the top of the page written in, COULDN’T MISS IT sized font.
Sorry Mattia
Disable auto home at startup in device settings first.
Then show your firmware settings, most likely the homing direction is not set correctly. You can also try to send $RST=* via console to reset the laser.
