homing
[ver:1.1h.20220925:]
[opt:v,15,128]
target buffet size found
ok
Alguém consegue me ajuda com esse erro, a maquina não conecta direito, o laser se mexer até chega no eixo fica batendo, só para quando desliga, não consigo fazer nada.
homing
[opt:v,15,128]
ok
Can someone help me with this error, the machine does not connect properly, the laser moves until it reaches the axis, it keeps hitting, only stops when it turns off, I can’t do anything.
Do you have homing limit switches on your machine? It doesn’t sound like it. Unselect " Auto-home on startup" and you shouldn’t have a problem. Make sure you manually place the laser head in the front left corner before starting the software.
Maybe have a look here additionally: Setting up the software - Diode Laser Wiki
