I am asking for your help. I have lost all of my design files, and now I am unable to engrave photographs with my laser; it either burns the material or the output doesn’t turn out as I’d like. I have a Sculpfun S30 10W machine—could you please share the settings you use to get the best results when engraving photographs?
A burglar broke into my house, and my PC was stolen. I’ve since moved on to a new PC, so I’m starting from scratch with nothing. I’ve been running tests for nearly five days now; I’m very close to a solution, but it’s proving to be quite a challenge. I’m hoping there might be someone else using a Sculpfun S30 10W who could share their settings—perhaps they’ll align with what I need.
I have the S30 10w but like I said, the image and material will make a big difference. If you are already close, I doubt I could add anything to improve your results.
Sorry to hear this, hopefully they will capture the persons responsible. Usually, the reason I hear for the loss is a PC crash or HD failure. But the response is always the same… If you have important files on your PC, save a backup copy somewhere NOT on that PC.
iCloud
Dropbox
Google Drive
OneDrive
NAS (network access storage) box
DVD ROM
Thumb Drive
A second PC
As you can see, there are a lot of options for having backup copies. But do not run Lightburn files from these options. Always load and save on your local PC, and backup when you are done.
If you are close to it, just note them down to have a backup. Nobody can help here, since, as Mike said, the nuances you might need now will differ from workplace to workplace fundamentally.
