Sculpfun S30 Pro Max Bluetooth upgrade
Has anyone already upgraded the 32 bit Sculpfun mainboard with a bluetooth module for wireless data? Which one are you using and where to find a install instruction. A HC06 module seems suitable but is it the best option?
The S30 mainboard already supports it out of the box. You only need to add an antenna. All the guides and the firmware can be found here:
Thanks very much. That’s good to hear. I will order a antenna.
