Good day. I’m having a problem with one of my Sculpfun S30 Pro Max 20W lasers (I have two). It randomly stops working occasionally, with the laser on. The X and Y locations of the stops, when they happen, are also always random. This suggests that it’s not the generated G-code.
I’m using it connected to the Sculpfun TS1 module. The firmware is the latest version (1.1.32). Version 1.1.31 also had the same problem.
- The motherboard is model XY-DLC32-QH v1.2A, also with the latest firmware version.
- The USB cable is shielded and short.
- The machine is lubricated.
- The SD card is not corrupted. I always save the G-codes first on the computer and then copy them to the card. I don’t overwrite files. I use short names without special characters.
- The power supply is original and stable.
I’ve already tried all the recommended solutions, but it continues to have these interruptions from time to time.
The other one, after I updated the firmware, stopped having this problem, but it has a different motherboard model (XY-DLC32-MC v1.2).
Is anyone else experiencing this situation or has already solved this problem?
I appreciate any help in advance.
