Sculpfun S30 Pro Max HELP
My Sculpfun laser banks to the back right corner every time I try to use frame or start. The homing seems to work. I have been using this laser for about a month and it worked fine. A couple days ago it started sticking in the middle and the laser would stop or it would double the images. I tried adjusting the screws for the x and y axis. I didn’t change any settings.I even tried opening other completed projects and the same thing happens. I tried reinstalling lightburn and adding this laser as a new machine but nothing seems to work. Any suggestions
sounds like you have mechanical issues… I would first check all your axis move freely and are not over tightened. Be sure all moving parts are aligned and bearings turn easily.
Is it doubling left to right or is it doubling up to down?
Sometimes sticking along the Y-Axis is caused by something loose allowing the gantry to become tilted, slightly diagonal, and binding.
Doubling left to right can be scanning offset if you’re using the engraver for bidirectional fill.
Feel free to post a picture of the doubling that you’re seeing.
Go through all these steps to adjust your mechanics correctly:
