Hi everyone, I’m new to this world, and I have a problem with my sculpfun, I ran the material test on lightburn, the first day the machine worked, the second the machine started to stop cutting, I reran the test this practically happened to me… I have already checked/cleaned the lens, I use the air assistant…
What were you trying to accomplish?
Did you want boxes or black squares?
Did you check focus with the little metal bar?
How thick is the material?
What is the test material?
How long have you had the machine?
Hi, thx for answer, in order: I tried to cut the the polywood with lightburn material test
i checked the focus with metal bar polywood is is thick 3mm machine is new… has 3 day
