Update: Solution was to manually add and follow instructions shared in the response.
Trying to setup my S6 Pro connected to an older MacBook Pro. Downloaded CH340 Driver - used tried multiple versions with no luck. Laser does react (jolts slightly) when LightBurn searches for it but won’t show it in the discovery window.
I’m at a loss on what to do. Here’s where I downloaded the driver: CH340 Drivers for Windows, Mac and Linux
I tried V1.5 first without luck then went through the uninstall process and tried 1.4 and 1.3 - none seemed to work.
Is there a way to manually connect and calibrate the laser?
Any solution or setup suggestions welcome.
A
