Hello.
When trying to setup the Sculpfun S9, we have stumbled upon an issue. We are able to functionally use the laser and have it set up with the correct coordinates on startup (bottom left corner). However, when we click the home symbol in the Move tab, the laser constantly bumps into the railing and after stopping, the new coordinates show as x: -451, y:-451.
Any help with solving this issue would be greatly appreciated.
The S9 has no limit switches. You can’t use homing and absolute positioning with this laser. Move the laser manually and use “current position” as starting position.
Or you add limit switches. A guide is here:
