Good afternoon everyone, I need your support, I have a sculpfun S9 with the Mainboard that has the following defect:
It turns on, the led on the laser unit lights up, but when I ask to turn on the laser, it does not turn on. I replaced the Mainboard and everything works. I have electronics skills but without a diagram I cannot identify the possible faulty component. Can anyone help me? Thanks
Check out the documentation of the MKS DLC boards. Those are the template of the Sculpfun boards, at least at the beginning. It depends on which version you have.
Hi, can i have a link for MKS DLC boards? thanks
Just google for MKS DLC schematic.
No one is a scupfun board
I know. That’s why I said you need to check the version of the mainboard you have. The first generation was nearly identical, the next ones have evolved. Though nearly all mainboards use the same schematics and pins for the laser control. So all are similar. You only need to check the main functions and find them on your board. Not that difficult.
