I have been using a Sculptfun S9 laser for a month and a half. Here is my problem: after engraving metal, I noticed a sudden loss of power. My engraving tests no longer produce the same graphical results.
Checks performed:
The lens is not damaged.
I haven’t changed the power supply.
No module has been added to the laser.
I have cleaned the lens as well as the diode inside the laser.
The diode does not seem to have any defects.
I have check the $1000 already
Additional details:
Machine: Sculptfun S9
Controller and firmware: LightBurn / GRBL
LightBurn version: No, I am not using the latest version
The issue is new; it hasn’t occurred before
Computer and operating system: Windows 11 and Windows 10 on two PCs (Lenovo Legion Y540)
I am engraving on zinc (with ventilation). Although zinc is reflective, this is not the first time I have engraved it without any issues. I have re-inspected the lenses and the diode without noticing any defects. I also tried changing the spacing between the diode and the lens without success; the laser still makes a line.
I have attached a video of the laser in operation as well as two graphical tables with the same parameters: one is much more engraved at 20% power than the other at 100% power.
I am ready to perform any type of repair from home if you have any suggestions for identifying the problem.
Trying to move the focal point by moving the lens is not a good idea. However, make sure you are not confusing the protective glass disk with the actual lens. If you did take the lens out, make sure you reinstalled with the curved side in the right direction.
It still makes a line in what material? Visible line or burn line?
Everything seems correct to me - not sure if your origin is thought it should be normally front/left?
I would be inclined to think laser decay try running this for me . which ever fits your module power best. Power test 5W.lbrn (130.7 KB) Power Test 10W.lbrn (145.8 KB)
I think I made a mistake; it is probably the protective glass. The diode inside the Sculpfun S9 is completely soldered, and only its position within the heatsink is adjustable relative to the protective glass.
Below, I am attaching a photo of the components I am referring to:
This should not be part of the optical stack of the module, should just be - as you said - a protective passthrough glass - so it should not interfere unless is damaged.
Without it does the laser power get better?
I would recommend getting in contact the manufacturer for better diagnostics.
I tried to follow the instructions in the video, and indeed, my laser has a defect; its spectrum is completely different from the one shown in the video.
I will document as much as possible in a final post about the origin of the issue, the problem, the solution, and advice on how to avoid such issues once I receive the last response from the supplier.
I finally got to the bottom of the issue. Support responded regarding the image I sent. Indeed, there is a defect in the laser. They kindly asked for my address to replace this part
I think the laser might have been damaged by the zinc. I switched materials, and one of them had an extra coating, which might have created better reflection.
Or it could be a manufacturing defect…
If you have a problem with your laser, you can consult the support video to check if your “spectrum” is viable or not.
